bench race air dyno my 489 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 04:22 PM
Last journal entry: was hoping for better than this
I'm going to put together (fingers crossed) this winter my bbc stoker
looking on picking a few peoples brains.. as I'm sure a lots changed since 2002 when I bought all the parts for this build...
it's a standard bore 4 bolt 454 that will be bored 30 over and to piston to wall clearance that srp list for the pistons..
the pistons are dome type yeilding a 10.2 to 1 static compression with 118cc heads... my heads are 121cc
srp doesn't list it but I'm going to guess that their compression listing is with the piston at zero deck...
the intake is a dart single plane.. picked single plane as I plane on efi down the road and it's not going to loose to much low end at 489 c.i.d.. and in efi.. it not be much of a factor..
the heads are darts pro 1's 345cc(not cnc ported) but will be port matched to intake gaskets the intake valve is 2.3" and the port flows398 @.800lift/28"
the exhaust port is raised .3" and exhaust valve is 1.88" and port flows 266cfm port is 129cc
the cam is a solid roller
I have a 3 piece timing cover and the "hex-a-just" timing set to play with the timing to "dial in the power" at the track..
I haven't done anything but have the block magged..
in an engine like this what to I leave on the table not bringing the piston deck to zero?
untill efi I have 5 carbs to test on it.. 3310 750 vac 2nd, a 750 d/p and a 850 full race bearclaw, a 800 cfm q jet, and a standard q jet,
I have 2 dissy's a MSD billet and a g.m. points type converted with a crane convertion kit..
the bottom end is all good stuff as I plan on spray (2 stage)
lunati crank (4.25" stroke) and crowler rods (6.385")
full rollerized s/s rockers and arp everything... and march serp belt system...
windage control /etc/etc
what you say... bench race this...
was going in my 70 chevelle, but thats gone.. so it'll be in my 71 c-10 3800 lb's, th400 g/v and reargear up in the air, stall converter I have is 3300-3500...
anyone have a dyno sim.. to get a over inflated hp/ft lb numbers out of..
should I look at different cams?
truck will be a weekend toy/ summer toy with some track time..
spray will be after I get it to hook on its own.. if that ever happens..
Flame suit on
computer dynos go..
Old 10-23-2012, 04:26 PM
625hp
550ftlb
Old 10-23-2012, 04:28 PM
Originally Posted by lmsport View Post
625hp
550ftlb
my 454 at 8.75 to 1 made 525 ft lb and 500hp
Old 10-23-2012, 04:34 PM
35WINDOW's Avatar
Last journal entry: Engine!
I'll say 675 hp
680# TQ
It should definitely put a dent in your Wallet (buying Tires! )
For comparison's sake, I have something kinda similar, in that the Duration is the same (.248/.254 @ .050 & 110 LSA), 10.2:1, however my Lift is .680, my Heads are AFR 315's and it's a 540-my Engine put out 775.5 hp & 740# TQ-
Old 10-23-2012, 04:43 PM
Old & Furious
Looks good i dont know much about big chevy but you seem to have all the bases covered. Cam doesnt look whimpy at least. I have never installed a cam too big just valves that were too small. LoL
Did you have the cam and crank lined bored. I hear it is a problem with big chevy. That is why aftermarket blocks are such good sellers.
The closer your going to come to 500 cubes or more the bigger the cam needs to be. Just as a rule but nothing to help on big chevys.
This is the standard for engine math and performance tuning. If you really want to calculate it all out.
Four-Stroke Performance Tuning: Fourth edition: A Graham Bell: 9780857331250: Amazon.com: Books Four-Stroke Performance Tuning: Fourth edition: A Graham Bell: 9780857331250: Amazon.com: Books
Old 10-23-2012, 04:59 PM
I'm assuming a 750 carb as I dont know what a 850 bearclaw is.
Head probably only flows about 340 at 0.600in lift.
Cam is too small for a really big hp number but will run well on the street. With a bigger cam, and more compression, you could get 750hp.
Old 10-23-2012, 05:06 PM
ever hear of a guy called barry grant
or his later line of carb demons
Old 10-23-2012, 05:28 PM
Old & Furious
Is the race carb street able. They usally arent. I would go big. 750 dp is a great carb in your hp range but if your going for big power might as well get it out of the way early since you will have to put in tuning time on any carb.
The edelbrock 800 carb i had on my poncho was always too small. Had a holley projection 1000 cfm and it was terrible junk but wot worked. So as long as it was floored it made power. But it was never an issue of too much flow making the engine hit soft down low even with the big throttle body. It was nasty down low. 245 tires were not even noticed by the engine. If it coughed which the projection did all the time it would blow the tires away. Like the car sneezed. Boug-roar-screech
If you had a 1050 dom i would say to run that.
Old 10-23-2012, 05:30 PM
Ooh yeah, that guy.
The last sooper-duper BG carb I dynoed would not maintain a consistent A/F ratio after sending it back to be rubbed on a few times.
I use Willys or Braswell cuz I dont have time to straighten out some shiny carb from Summit.
I have built and dynoed almost the same engine you want to build, except the cam I used was even smaller for use in a daily driven car, the disp was 496, and the intake was a dual plane. That engine made 575hp on pump 93.
Old 10-23-2012, 05:46 PM
Ooh yeah, that guy.
oh, so you're use'n 3000.oo carbs.. how much for that bridge again?
the bearclaw and demons pre 2009 are fine.. like everyone else he started cutting corners to stay in biz.. it didn't work..
as far as "that guy"
he IS the reason holleys carbs are 100x better than the garbage they sent out the door before he came along.. it forced holley to make better parts..
Old 10-23-2012, 06:01 PM
On a real racing engine...yes, I have spent over $3k for a single carb. I have spent $4k on a gauge legal two barrel for a LMSC engine just to get 10hp more than a $2k carb.
I gave away the 850 BG I mentioned and I would not take another one if they were free. Good luck with your project.
Old 10-23-2012, 08:34 PM
love the way you compair a 2-3-4 thousand dollar piece to a 350.oo-550.oo one.. comical at best
want to compair a 20 dollar cast piston to a 190.oo one next..
Old 10-23-2012, 08:43 PM
327NUT's Avatar
What are "crowler rods"
Old 10-23-2012, 08:56 PM
a typo..
Old 10-23-2012, 09:06 PM
vinniekq2's Avatar
Im going to guess 700 hp plus or minus depending on final choice of parts. The 106 icl is curious for that large of engine.Use an 850 X as a minimum size.The flow numbers are important for a better guess.
Pump Gas Versus Race Gas / dyno results ?? fastlaners Engine 8 04-30-2011 10:51 PM
California Air Pollution car race info and history ?? xxllmm4 Hotrodders' Lounge 4 02-01-2009 04:35 PM
dyno info on 7 BBC race heads on a 502 crate mill bullheimer Engine 1 04-08-2008 08:14 AM
New combo, lets bench race. curtg21 Engine 9 01-25-2008 12:59 PM
drag race air bag 68chevelle_ss Suspension - Brakes - Steering 5 06-03-2004 07:10 AM
