Bench Test T.C.C SOL 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2009, 07:10 PM
can I bench test the overdrive solenoid with 12V how does it work i can blow threw it with no power to it.Also do i need to ground the SOL threw a pressure switch when in the trans just one more thing that may not work how about running pos and neg threw the plug in case i want the lock up for freeway controled by a toggle I now it has to be turned off when slowing down but first I need it to apply thanks Wayne
Old 03-30-2009, 07:42 PM
LEE EYES's Avatar
Last journal entry: TBI experiment.
a switch will work. just stay on the ball. and i believe its a n/c solenoid... not sure though.
Old 03-31-2009, 04:56 PM
scrot's Avatar
I believe the solenoid has a nylon check ball that might jam over time. If you have a question about it, I would go ahead and replace it.
Adheision test. BarryK Body - Exterior 11 04-08-2005 05:01 PM
engine test bench speede5 Engine 6 01-09-2005 01:18 PM
How to bench test mustang tach? stang_steve Electrical 0 07-21-2004 09:12 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 10:34 PM
