Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bench testing a radiator fan switch
Old 10-17-2012, 02:38 PM
tech69 tech69 is offline
put up or shut up
I guess I should also note the fans never came on after switching the heat sensor but am guessing it's because the new T stat is stuck closed and the sensor is not getting coolant over it. I'll switch out the t stat but am wondering if the 12 volt direct killed it. It sure burned my finger.
