Benchtop Material - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 07:23 PM
Benchtop Material
I just finsihed my new work bench, its built out of 2x4's and mdf board for the top(by the way that stuff is really heavy), i want to get a peice of sheet metal made for the top, my dad's shop uses galvinzed but i want to get maybe a 20 guage regegular steel so i can tack stuff to it when building, the bench is inside but what about rust? does anyone uses carbon steel and do you have to keep it oiled?
Thanks
Brendan
Old 11-05-2005, 07:34 PM
poncho62's Avatar
Wiki Edits: 5
I wouldn't be welding to metal on top of wood. If it was a steel framed bench, that would be different.
Old 11-05-2005, 07:41 PM
Fast Orange's Avatar
If you're planning on welding on that bench,you better find something heavier than 20 ga.I'd suggest finding a piece of at least 3/8" plate,otherwise you'll burn through it and warp it.
Also,if the top of the bench is 2x4 now,covering it with sheet metal and tacking to it might lead to setting the wood on fire-
George
Old 11-05-2005, 07:59 PM
Metal over wood How about a 3/8" metal top? It's a little pricey but heck you can do about anything you want with it. A vise will anchor SOLIDLY and a few strategically drilled holes come in real handy also, plus you can tack or even weld heavily on it if you need to. Once you work on a heavy metal top you will not want anything else
Old 11-10-2005, 11:03 AM
modas's Avatar
Dazed and Confused
Last journal entry: Trunk Part 21
I put a piece of 3/4" plywood down, followed by 1/4" cement board, followed by 1/8" plate.
I've got no problem welding direct to the plate in terms of heat transfer to the plywood. Works great.
Old 11-10-2005, 12:48 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hit the scrap yard and find a piece of heavy plate steel..Like Oldred says you can drill and tap for clamps to hold things exactly in place while you are welding..this can be important if you are making anything that needs to be precision..and if you get a really stout piece you can whang and whale on it and not hurt anything..
OMT
The best V-8 ever made NXS Engine 167 10-16-2011 08:10 AM
How much material for a 34 ford interior? jaxhome Interior 8 11-13-2005 08:27 AM
Which material??? SR-71 Body - Exterior 8 09-12-2005 05:49 PM
Material for custom fiberglass panels Toyman Interior 13 08-19-2005 02:00 PM
Material quaility?? Bluepen Interior 2 12-02-2003 05:33 PM
