Bend Pak Lift or another brand - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 07:22 AM
MAX18's Avatar
I need to get a low rise lift, cause the ceiling is just 8ft. I checked the web and found that Bend Pak has one that has nothing in the center of it. I believe it's a P-6. Made for pit type places. I like that idea cause you can get to the middle of the underside of the car. Does anyone have this type or maybe another brand? What should I look for in a good quality lift?
Old 03-25-2006, 07:45 AM
powerrodsmike's Avatar
Wiki Edits: 161
I have a bend pak lift. It is the full height, (12' 8"), 7500# version. We have had it for 12 years. I have never had a problem with the lift as far as the quality or it's capabilities. I haven't heard of anyone complain about the quality of a bend pak. We bought it because we felt it was more versatile for the type of work we do as it allows easy access to just about the whole car underside. The posts do get in the way of opening the doors if you are working on the inside and the outside at the same time. If I had to do it again I would get one of the ones with the angled posts. The only drawback to the 2 post is that doing anything requiring the suspension loaded such as exhaust work, pinion angle and ride height adjusting steering binding issues,etc, would be better done on a 4 post. I know that doesn't answer all of your questions, but I hope it helps. Mikey
BE different....ACT normal.
Old 03-25-2006, 11:10 AM
67 Deuce 4 Me's Avatar
Bowtie or Die!
We have 6 lifts in our shop. The newest is a Bend Pak. It is no where near the quality of the others. Its slow we have bent a couple cheaply made accessories that came with it. the ramp design sucks. I don't like it. But may be great for a home shop. Personally I wouldn't buy one .
Old 03-25-2006, 11:15 AM
Wiki Edits: 161
They must have been better made 12 years ago. I use mine every day at my
non-home shop. So which ones are the good ones?
Old 03-25-2006, 11:54 AM
Interesting thread, I too have been thinking about buying a lift and was looking at the bend paK. Duce, powerrod which models do you have?
Old 03-25-2006, 12:15 PM
Wiki Edits: 161
Oldred- I have the SR 7 AC. 7000# (sorry I said 7500# before), Mfg date 1/94. It is a 2 post. full height.
Old 03-25-2006, 01:07 PM
For those with low ceilings where a full height lift won't fit, check out Kwiklift:
http://www.kwiklift.com/
Old 03-25-2006, 03:24 PM
Bowtie or Die!
"Rotary".............. http://www.rotarylift.com/ I love this lift I work on every day for almost 5 yrs. Its a asymmetric lift, but I think they are the best lift for the money IMO. But for a home shop I would say Bend Pak would be fine. Look at my photo album you can see my nova sitting on the lift if your curious.
Old 03-25-2006, 04:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Took a look and the guys at Rotary have a revolution model for home garage use..may be worth a look..
Sam
Old 03-25-2006, 06:14 PM
Wiki Edits: 31
at the autoshop at my school, we have 6 lifts, there is an old Bend Pak, it is good, 2 post 9k max, doasn't have an automatic saftey disengage lever like the others, you have to pull the pins manually on each side. our new lifts are AAMCO 2 post Asymetricle, there real nice lifts, quick, the arm locks can get stuck tho, then it takes worming to get them released.
Old 03-26-2006, 07:43 AM
MAX18's Avatar
Thank's for the input guy's.
Old 10-01-2010, 03:14 PM
Thanks powerrodsmike for giving us a mention. We used you in our testimonials page . Come check it out!
1.7 to 1.8 ratio BBC rockers much diff...? Bumpstick Engine 6 04-28-2005 11:41 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 08:59 PM
Anyone have a Bend Pak lift? AlanTA Garage - Tools 1 09-01-2004 02:03 PM
4 post lifts Beenaway2long Garage - Tools 11 01-28-2004 06:38 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
