Bending Flat Bar - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 09:07 AM
Bending Flat Bar
Any of you gentlemen out there have a quick way to form 2"x1/8" flat bar into a circle? I need to make a ring to fit my CO2 tank into on my welding cart. It is a Harbor Freight cart and I never liked their chains on the cart for holding the tank in place.
Old 01-11-2012, 09:28 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
torch and something to bend it over/around
it doesnt need to be round to hold the bottle
you can use flat that hits/touches the bottle on 2-4 sides
thats all i have, and a rubber bungi cord (so it doesnt rattle, not to hold it in)
Old 01-11-2012, 11:18 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
This may sound a little low-class, but I recently had to make a new Transmission Tunnel/Cover, and I used one of these to get my contour right, using 1" X 1/8" flat strap-it worked great-you could do 2" by reversing it-
http://www.harborfreight.com/gear-dr...ler-36790.html
Old 01-11-2012, 11:37 AM
daoldbuick's Avatar
This may sound simplistic but why not just bend it around the CO2 tank?
Old 01-11-2012, 01:07 PM
35terraplane's Avatar
Bending flat bar
A old guy showed me this, put it on a flat solid surface the cement floor will work. Take a ball peen hammer, bigger one, starting in the middle just start hammering, you will be surprised at how fast and quick it goes into a circle, as you hammer you work your way to the ends.
I learned that 30 years ago, and I still have the first one I did, that was S/S, hanging on the wall.
Bob
Old 01-11-2012, 02:11 PM
& matts38chev
Bob
I have done this on the vise, with the jaws open about 2" - 4"
its just not very pretty without a lot of work
Old 01-11-2012, 02:33 PM
ogre's Avatar
the 'Duracell Project'
1/8''? i'd just wrap it on the tank, or a smaller tank.
it will bend real easy
Old 01-11-2012, 02:41 PM
& matts38chev
piece of cake
Old 01-11-2012, 03:11 PM
Since just bending a piece of 2"x1/8" is so simple I am assuming you mean bending it NEATLY which is not as simple as it sounds. Pounding on it with a hammer, either on a concrete floor or over a vise, will certainly yield a circle but it may be a bit crude looking. To do this as neatly as possible I would suggest you bend it cold because heating it with a torch will almost certainly result in uneven bends or even kinks unless you could manage to get it heated evenly the entire length but with 1/8" why even bother with heat? The best way would be to wrap it around it around a cylinder, if it's long enough you can hold it by each end and wrap it into a complete circle if that's what you need, just be sure to pull back on it as you bend it otherwise the side opposite the connecting ends will tend to bulge and leave it "egg" shaped.
Old 01-12-2012, 10:22 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
I think, what you want to use is one of these roll formers: http://www.baileighindustrial.com/be...bender-rm7.php
If you read the specs, they say min 10 inch, that's a pretty tight circle.
Old 01-12-2012, 11:40 AM
Wiki Edits: 647
This will work also.
Old 01-12-2012, 12:53 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Actually one can build that sort of tool to make curves in lat stock..just depends on how much of that work one needs to do if it is needed or not. For one or two pieces form the flat bar around something round works fine..
Sam
Old 01-15-2012, 05:36 PM
bending flat bar
The quickest way is to just wrap it around the cylinder, you should be able to bend the 1"x 1/8" by hand. Another way would be to go to the scrap yard and have them cut you a 1" piece of scrap pipe as wide as you want, cut that across into two parts, get 4 pieces of angle iron cut to size to weld on to the 2 pieces of pipe that you cut in half (at either end) drill holes in the angle iron for long bolts or pieces of all thread to go through get 4 nuts for the all thread. run the all thread through the holes in the angle iron clips on both halves the pipe put the nuts on them and you have yourself a clamp, get a piece of square tubing or angle iron and run this across tour weld cart and put your tank in place with the clamp installed and tack the clamp in place, remove the tank and finish welding out the bracket, when all has cooled down mount your tank, tighten the nuts on the all thread and your ready to go. Hope this helps lowmerc
Bending Tube 62slantsix General Rodding Tech 19 06-03-2010 03:04 PM
hydraulic flat vs mechanical flat sexypizzaman Engine 20 10-16-2009 01:10 PM
bending aluminum stea Hotrodding Basics 5 06-17-2006 11:31 AM
pipe bending Kenman Hotrodders' Lounge 1 05-28-2004 02:15 AM
mandrell bending fire power Engine 2 03-27-2003 03:36 PM
