Bending Tubing - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2010, 06:35 PM
Bending Tubing
I thought of a neat trick for bending 3/8 steel tubing while trying to figure out how to make a set of power steering lines for my Jeepster. I needed to start the bend as close as possible to the flare nut, and make the bend with as small of a radius as possible. I made a jig for bending the tubing, but the real trick is to slide a length of spring armor off a 3/16 brake line inside the 3/8 tubing to prevent it from collapsing. After bending the spring can be pulled out easily. I don't know if anyone has tried this, but it worked great for me and would work with any tubing bender.
Old 11-21-2010, 06:45 PM
S10xGN's Avatar
Gotta love a turbo!
Nice work! Is that main support hoop made from washers?
Russ
Old 11-21-2010, 06:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
That's pretty nice looks like it works really well also.
Cole
Old 11-21-2010, 07:44 PM
65ELCMO's Avatar
Cool, I will try that the next time I need a tight bend.
Old 11-21-2010, 07:49 PM
Grease_Fever's Avatar
68 Pontrolet
Nice work!
A guy told me once he used to fill his lines with sand to keep them from collapsing. Anyone ever try this?
Old 11-21-2010, 07:56 PM
ScojoDak's Avatar
Mopar for life!
Yes it does work depending on the wall thickness and how tight (radius) the bend is.
Old 11-22-2010, 09:37 AM
302 Z28's Avatar
Originally Posted by Jason Russell
Nice work!
Sand trick only works on thin wall, will not work on anything other than copper. To work properly the sand must be compressed somehow.
Vince
Old 11-22-2010, 01:08 PM
Very cool, I just did the brake lines on my Rambler, that would have came in handy.
Old 11-22-2010, 01:59 PM
Wiki Edits: 31
I have a simmilar bender but for brake line, I just bend it by hand. just have to do it slow and real careful... good idea about the spring inside. I'v never had much luck bending 3/8" tightly like that
Old 11-22-2010, 05:13 PM
302 Z28's Avatar
A high quality tubing bender will handle tight bends. I have seen some very impressive tubing work by some of our instrument tech's.
Vince
Old 11-22-2010, 06:55 PM
Nice job of bending! We have a post that 49 T&C started called "whatdidja-make" you ought to post it up there too!
"Whatdidja make?"
Old 11-22-2010, 06:59 PM
Nice work!
Any kind of tube bending is a give and take. I have used sand with good success and I have used ball bearings.
Old 11-22-2010, 07:10 PM
bentwings's Avatar
bentwings
I've used a similar home made bender made from pulley sheeves. Costs a little more but still a lot less than a bender.
Old 11-23-2010, 11:07 AM
Imperial makes tubing benders that will bend tubing very tight. They come in many different sizes. Unfortunately, you need a different bender for each size of tubing. I have 4 or 5 of the Imperials ... and they do work GREAT
Old 11-23-2010, 12:11 PM
Hotrod-Bikerman's Avatar
Nice work!
I wouldn't use sand on any lines where abrasion would be an issue such as brake lines, hydraulic lines as any residual sand could cause a system failure.
Making dies and rollers to bend square tubing cboy Garage - Tools 20 11-05-2012 05:59 PM
Building bumpers APalusky Body - Exterior 5 01-13-2010 05:20 PM
How To: Tubing Bender Twisted Minis Garage - Tools 65 11-18-2008 04:09 PM
bending rectangular tubing F3RR3T Hotrodding Basics 12 08-29-2008 07:39 AM
Steel tubing for frame and other questions TheBasementHotRod General Rodding Tech 4 11-29-2005 05:51 AM
