bent axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 08:07 PM
bent axle
I have a 72 chevelle 10 bolt with a bent axle. Is this a repairable item,or should I look for a new axle? It is in a 54 Chevrolet truck with a low HP 283 and 350 turbo. I can probably figure out how to remove it,but any help would be great.The wheel runs out of true.
Old 05-11-2005, 08:38 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Did you bend the housing also?
Old 05-11-2005, 09:39 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
change it out
Those axles are not too hard to find and once metal has been bent it has lost some strength..not worth it to try and fix..IMHO..
OMT
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
front axle help needed 30dodgeboy Suspension - Brakes - Steering 25 11-15-2004 09:37 AM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 04:20 PM
8.8 - Bent Housing or Bent Axle? 96cobra Transmission - Rearend 3 12-16-2002 05:30 PM
