Bent or burnt valves, how do you tell without a leakdown test? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 05:32 PM
I have an engine miss I've been trying to get fixed. It seems I've checked everything but the valves. I'm trying to rule everything else out before I start yanking heads.
I did a compression check and I got over 200lbs in each cylinder. My engine is an 11-1cr SBC 406. All of the cylinders were within 5% of each other. Could you still get excellent results with bad valves? I don't have a leakdown tester and I don't know anybody with one. I have already spent enough money and I don't really want to buy one if I don't have to. It would actually be cheaper to yank the heads and check them. Of course I don't want to if I don't have to.
I guess what I'm looking for is signs your valves are bad. I've heard backfiring and flames out of the carb are potential signs. I don't have either issue.
Thanks for your time
Old 03-29-2009, 09:55 PM
I'm no expert, but if you've got good compression, I don't think you have burnt or bent valves. If you've checked everything else, it might be a bad cam, lifters, rocker? I would re-check again though. What do the plugs look like?
Old 03-29-2009, 10:45 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
maybe a valve adjusted too tight?
Old 03-29-2009, 11:12 PM
techinspector1's Avatar
Wiki Edits: 326
Nothing wrong with the valves. Keep looking.
Old 03-29-2009, 11:21 PM
Thanks for the replies. My spark plugs have soot on them, I do know its running rich. I have been tuning my Holley and I've even swapped carbs with no luck.
I did install a new cam last year. I've always heard if it goes bad you will hear alot of noise from the excess clearances. I don't hear any pecking or ticking. I'm pretty sure its ok.
I'm going to swap in another distributor today and see what that does.
Thanks for your time and replies
Old 03-29-2009, 11:49 PM
Wiki Edits: 326
Drop your fuel pressure to 5 psi at the carb.
Burnt Valves? steveyb4342 Engine 4 05-31-2007 06:28 PM
Camaro compression test....burnt valves??? Rubberman2003 Engine 4 02-08-2004 05:15 PM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 09:34 PM
Cylinder Leakdown Test Hawk51 Engine 2 08-25-2003 01:08 PM
Leakdown Test Puzzle MI2600 Engine 2 06-06-2003 04:03 PM
