Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bent drive shaft
Old 03-14-2009, 03:50 PM
Ken Milesky Ken Milesky is offline
Bent drive shaft
I've bent my drive shaft and need to know a good sorce to have one made that will hold up to 525 hp.The stock mopar shafts bent twice when I bang 2nd gear. The truck is an 84 Dodge Ramcharger with a 69 340,solid lift cam,aluminum heads,double quad tunnel ram,60 over pistons,steel crank,69 727 trans with shift kit and 3600 rpm stall converter,69 dodge rear with a new detroit locker dif. Need a good drive shaft. Please help ,Ken
