-   -   Bent drive shaft (http://www.hotrodders.com/forum/bent-drive-shaft-154987.html)
Ken Milesky 03-14-2009 02:50 PM
Bent drive shaft
I've bent my drive shaft and need to know a good sorce to have one made that will hold up to 525 hp.The stock mopar shafts bent twice when I bang 2nd gear. The truck is an 84 Dodge Ramcharger with a 69 340,solid lift cam,aluminum heads,double quad tunnel ram,60 over pistons,steel crank,69 727 trans with shift kit and 3600 rpm stall converter,69 dodge rear with a new detroit locker dif. Need a good drive shaft. Please help ,Ken
richard stewart 3rd 03-14-2009 03:55 PM
Hi,
Give them a call, there in NY
Rich
http://www.dennysdriveshaft.com/c1_n...iveshafts.html
ericnova72 03-14-2009 04:53 PM
Dealt with Denny's, excellent stuff!
Big Don 03-15-2009 09:50 AM
Shaft question
Stans Shaft Shop in Gulfport Ms. He builds all of mine and is top notch. Just tell him what its for and all the specs. and he can build you one that will handle anyting. His prices are very fair and has a fast return on orders. He has been in business in the same location for some 25 years and was only closed for a few weeks when Katrina put 12 feet of water in his shop. He is a real straight-shooter and has dirty hands... My kinda guy.
