Bent drive shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 02:50 PM
Bent drive shaft
I've bent my drive shaft and need to know a good sorce to have one made that will hold up to 525 hp.The stock mopar shafts bent twice when I bang 2nd gear. The truck is an 84 Dodge Ramcharger with a 69 340,solid lift cam,aluminum heads,double quad tunnel ram,60 over pistons,steel crank,69 727 trans with shift kit and 3600 rpm stall converter,69 dodge rear with a new detroit locker dif. Need a good drive shaft. Please help ,Ken
Old 03-14-2009, 03:55 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Give them a call, there in NY
Rich
http://www.dennysdriveshaft.com/c1_n...iveshafts.html
Old 03-14-2009, 04:53 PM
ericnova72's Avatar
More for Less Racer
Dealt with Denny's, excellent stuff!
Old 03-15-2009, 09:50 AM
Big Don's Avatar
Shaft question
Stans Shaft Shop in Gulfport Ms. He builds all of mine and is top notch. Just tell him what its for and all the specs. and he can build you one that will handle anyting. His prices are very fair and has a fast return on orders. He has been in business in the same location for some 25 years and was only closed for a few weeks when Katrina put 12 feet of water in his shop. He is a real straight-shooter and has dirty hands... My kinda guy.
9 inch & Drive Shaft Swap Morgan22 Transmission - Rearend 2 06-21-2008 02:30 PM
Front drive shaft jrm123180 Transmission - Rearend 10 03-07-2006 05:32 PM
drive shaft for s10 ext neeper74 Transmission - Rearend 3 01-08-2005 05:34 PM
63 belair drive shaft jackal Transmission - Rearend 2 11-08-2004 06:21 AM
St-10/ 2 piece drive shaft question 85406 Transmission - Rearend 1 04-16-2003 01:36 PM
