Bent electrode
Hey Guys I have a bbc with a 6-71 blower.I just changed the spark plugs and noticed the electrode on the number 7 spark plug was bent . The peice right above was fine,not bent or push down touching the electrode. Car runs fine.What would cause that and is there anything i can check to know for sure the engine is ok.
Two reasons that will happen, The piston kisses the end of the plug, meaning the plug reach is too long or a piece of piston or valve went through the motor but kissed the plug on it's way out.
The third reason that can happen is it's put in that way and just missed. Gut would be the third reason. You'll know soon enough once you check it in a day or so after running. |
If I drop a plug when I am installing it, Chances are it bends the electrode. I always check it before I install it. Just a thought, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Doc here,
Something small could have nicked it passing through the induction system (like a throttle plate butterfly screw fell out) and spit it out the exhaust.. Not sure if a heavy Detonation would do that on a blown engine or not..But it may be something to consider.. Most likely, as was said , It probably went in that way and you just missed it..maybe mashed it on a header trying to find the plug hole.. I do know if you over~torque the Plugs the gap can spread, but never heard of one closing without help.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
If I read this correctly it's the centre electrode not the ground electrode that's bent. I've seen this on propane engines with too much total timing, propane likes a short fast curve and seems to detonate up high rather than under load. By all means do a leak down test, but if the insulator is blistered you may have detonation.
I seem to remember some blokes using 2 different heat ranges in the same engine (BBC) in the 70's. |
| 86 s-10 frame bent | catscan4free | Suspension - Brakes - Steering | 3 | 03-27-2007 09:46 PM |
| Bent pushrod on 502 CI Chevy | oldndragon | Engine | 8 | 08-08-2005 04:26 PM |
| bent frame | bullheimer | Hotrodders' Lounge | 2 | 10-29-2004 07:25 PM |
| 8.8 - Bent Housing or Bent Axle? | 96cobra | Transmission - Rearend | 3 | 12-16-2002 05:30 PM |
| help bent pushrods | wrenchturner | Engine | 9 | 03-27-2002 05:38 PM |
