bent Holley throttle shaft... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 11:20 PM
I have a 7508-1 2bbl Holley.It was rusted tight and the only way to remove and clean the blades was to take it apart.Well, what happened was that the shaft got bent.will any throttle shaft replace it, or do i have to buy a specific one for this carb?
Old 01-23-2011, 09:00 AM
sqzbox's Avatar
My pipes are my music
Application specific. Order a new base plate and it should have the shaft and throttle blades in it. Copy all #'s off the carb before you go to the parts store or, take the carb body with you. Might try Napa first. The Chinese parts stores second.
Old 01-23-2011, 10:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's a 2300 Holley. IIRC, the 2300 uses the same throttle bore center spacing as a squarebore Holley like a 4150.
So, you might try using the throttle shaft from THIS kit.
Obviously, another baseplate or shaft from a carb core off eBay would work.
Old 01-30-2011, 12:10 AM
So any shaft will work then?
Old 01-30-2011, 01:12 AM
sqzbox's Avatar
So, you "MIGHT" try using the throttle shaft from THIS kit.
Obviously, another baseplate or shaft from a carb core "LIKE YOURS" off eBay would work.
I capitalized and added some key words to cobalt's post I quoted you need to re-read.
I hope he doesn't get mad at me.
Old 01-30-2011, 05:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I seriously doubt ANY shaft will work. This just covers way too much ground.
You would be well advised to do some research:
Does the 2300 carb share the same throttle bore centers as a shaft I might want to use- like the Holley 1850 in the kit I linked?
Are the shaft OD's similar?
Will the replacement shaft have the same (or usable) linkage hook up points?
I think the first two points are not going to be a problem, if attempting to use the kit shaft. The third may or may not be, depending on the exact app you have (and of the donor, if different from the kit shaft).
'Course not, it's all good.
Old 01-30-2011, 09:06 AM
Maybe you should contact Holley Tech Assistance, they might know
http://www.holley.com/TechService/TechRequest.asp
holley leaking throttle shaft flaming79 Engine 22 06-14-2013 04:55 PM
Question on holley carb and throttle shaft eric32 Engine 7 09-30-2010 07:24 PM
throttle shaft bearings on holley carb grapro Engine 5 06-26-2004 09:54 PM
Holley throttle shaft bushings hemiford Engine 7 02-14-2004 09:02 PM
Whare to buy Holley throttle shaft bushings? newchevyman Engine 2 09-01-2003 12:07 PM
