bent pushrod - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2005, 12:51 AM
bent pushrod
hey all,
i have a 350 chev that i have bent a pushrod in. The rocker arm then twisted around so it was right off the valve. I replace both the rocker arm and the pushrod, but the rocker again continued to move back across the valve and was going to come adrift again. the motor is only about 300 miles old since a rebuild. it has fuellie heads and the rocker stud appears to be straight. any ideas on what the problem may be???
Old 04-04-2005, 12:58 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
valve
I would say you are in need of a guide plate. If that doesn't work. You would be looking at a bent valve.
Old 04-04-2005, 04:22 AM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
What kind of rocker arms?
Chris
Old 04-04-2005, 05:32 AM
poncho62's Avatar
Wiki Edits: 5
How does the top of the valve stem look?
Sounds to me, like you rounded it off a bit.
Ontario Rodders
Old 04-04-2005, 05:15 PM
They are standard chev rocker arms. The valve looks ok. would bolt on roller rockers fix the problem, as these are a lot cheaper alternative to setting up guide plates, hardened pushrods, screw in studs etc.?
Bent Push-Rod on Chevy SB 350! 32Hoopie Engine 12 08-08-2010 08:46 AM
Header leak or bent pushrod? Trav Engine 8 12-16-2003 05:25 PM
8.8 - Bent Housing or Bent Axle? 96cobra Transmission - Rearend 3 12-16-2002 05:30 PM
Bent Pushrod Chevy_SS10 Engine 10 10-02-2002 05:18 PM
