Bent rear axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2011, 03:08 AM
67Mustang Al.'s Avatar
Bent rear axle
Just when i thought i was close to finally dropping the Mustang off the hoist ,having solved all the annoying fluid leaks, i selected low gear with the car still in the air and heard a scraping noise coming from the rear. It is fitted with 4 wheel discs and looking at the right hand rear wheel turning over slowly i discovered i have a bent axle and the caliper was weaving trying to follow the disc as it moved side to side about 1/4 inch. I should have picked this up a long time ago but i didnt.
Question is , is it acceptable to straighten a heat treated axle either hot or cold or should it be tossed in the bin.
Any thoughts welcome.
Al.
Old 08-29-2011, 03:24 AM
SSedan64's Avatar
Not sure about the Axle.
You also need to check the Housing to see if the Axle tube is bent which is usaully the case.
Old 08-29-2011, 07:38 AM
thanks . So i guess a measurement is required with a straight edge of some sort to determine if the housing is bent.
Al.
Old 08-29-2011, 07:55 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would get another axle. JMO
Cole
Old 08-29-2011, 08:17 AM
Thanks Cole. I was just reading a few blogs on All Fords website and it seems no one attempts to straighten an axle, just replace it. I hope some Ford axles here in Aus are the same as the 67 Mustang or its going to be a pain to find one the same.
Al.
Is this rear bent? 1948 thames Transmission - Rearend 5 04-08-2007 05:02 PM
Bent axle? junkyardjeff Transmission - Rearend 7 07-11-2006 09:03 PM
Bent Pinion In Rear End...? 2 Fn LoW Transmission - Rearend 5 11-05-2005 07:10 PM
bent axle jamn50 Transmission - Rearend 2 05-11-2005 09:39 AM
8.8 - Bent Housing or Bent Axle? 96cobra Transmission - Rearend 3 12-16-2002 05:30 PM
