Bent rocker arm stud - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2006, 07:14 PM
Saltracer's Avatar
Just recieved a rebuilt motor from an Ebay seller. Motor looks nice, but one rocker arm stud is bent. Also broke the push rod and nicked the top of the valve. This is a stock pressed in stud on a 302 Ford motor. Can I remove the stud with the head still on the motor and press another in? I think the head will have to come off though, to check the valve to make sure it's not bent. thanks
Old 05-03-2006, 08:34 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
i don't know that much about fords.....on a Small block chevy once the stud has worked its way loose, you really have to go to screw in studs or it may walk on you again...so if you remove the stud i guess the same logic would apply....on a SBC when you go from pressed in studs to screw in studs you really need to machine the boss flat that the stud gets screwed down.....so i'm not sure how you can do that in the car. perhaps the ford guys can give you some specific advice that may help you out.
Old 05-03-2006, 09:12 PM
STUD IS EASLY REMOVED be sure to get the corect replacement rail rockers use a diferent stud than non rail when you drive in the new studdrill a small hole threw the castingand stud then drive a rollpin in that will ensure it stayes in place. cliff
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Broken Rocker Arm Stud, Help to Remove RAW Engine 10 02-15-2006 02:23 PM
Rocker arm wearing into stud and bending pushrods? Meangreen Engine 19 12-28-2003 09:59 AM
348 Chevy broken rocker arm stud NAIRB Engine 1 12-16-2002 04:56 PM
How to remove a rocker arm stud Chevy_SS10 Engine 17 11-29-2002 04:55 PM
