bent shock mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2008, 07:11 PM
bent shock mount
This might be a dumb question. On my 56 Chevy p/up the right rear shock mount is bent so that I have about a half inch height difference from the right
in the shock travel. The truck sits a little lower on the right. Could this be the cause of the lean? Also the springs are new, with about 200 miles on them.
Thanks....
Old 01-17-2008, 08:08 PM
31 five window
Last journal entry: grill and rear end
No ,shocks do not hold up truck,springs do. If rear springs are new how about the front?
Old 01-17-2008, 08:15 PM
406 bug's Avatar
9.82 @ 139mph
It Ain't The Shock- Un Bolt One End Of The Shock To Verify. I Would Look At The New Springs- Was It Level Bofore?
Old 01-17-2008, 08:49 PM
RE:bent shock mount
Actually, I don't know if it leaned before. It was not running when I bought the truck.I started the frame-off restoration right away.I changed the front springs also but didn't like the way it handled, so now i'm in the process of adding an "TCI" ifs. kit.
One more question.If the frame was bent would I be able to get the frame level on jack stands? With the jack stands the same height the frame is perfectly level side to side.Thanks...
Old 01-17-2008, 10:15 PM
406 bug's Avatar
9.82 @ 139mph
are you using 4 stands , (front rear). if so, and level, i would think you have a bad rear spring. if the 1/2 inch dif. is at the rear, i would swap left for right and see what happens..
What's the best way to mount shock absorbers??? Augusto Suspension - Brakes - Steering 4 01-10-2008 01:14 PM
Rear shock mount crossmember-How thick/location? marks914 Suspension - Brakes - Steering 2 12-19-2007 07:08 PM
1979 chevy k10 lower front shock mount hiball Suspension - Brakes - Steering 2 12-17-2005 09:52 PM
Rear Shock Placement, Angles ZipZ28 Suspension - Brakes - Steering 22 10-08-2005 02:52 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
