Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bernzomatic Mapp Gas torch q's
Old 09-12-2008, 09:55 PM
oldred oldred is offline
With that little outfit and the right tips you could do anything from cutting an occasional piece of heavy steel to welding body panels. You could cut, braze, solder, weld or even heat parts to bend and even weld Aluminum or braze cast iron. Once you have an acetylene torch to use for a while and discover what you can do with it you will be lost without it!
