Best 110 Volt compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2005, 12:22 AM
Last journal entry: Some pics
Given the limitation of 110 volt service, what is the best compressor and best deal? Something that would produce 10 CFM at 90 would be nice.
Old 03-05-2005, 10:48 AM
110 V compressor
Lots of luck. Looking at my Northern tool catalog, the most output it shows from a 120 V compressor is 6 CFM at 90 PSI, and I'll bet that it needs a 30 Amp circuit to do that. It says dual voltage motor, which means that you would be well advised to find 220 somewhere for it. I rigged a 250 ft extension cord using 12-2 with ground romex, (the kind of wire you install in a house wiring system), and a 30 A outlet and plug, in a plastic box. I plugged it into a plug that was meant for an electric dryer. The romex is rated for 600 V, and the plug and outlet were for a 220 V air conditioner.
Old 03-05-2005, 10:58 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Agreed. If you bite the bullet and go with a 220 you can get a nice compressor for decent money. I paid $430 for a compressor at Tractor Supply Company that will do what you want. It is rated for any air tools out there.
Chris
choosing a compressor oldred Garage - Tools 12 03-14-2012 09:40 PM
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 02:10 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
