Best 383 Chevy Headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2011, 08:29 PM
Howdy,
I've got a 1972 Chevy 4X4 with PS/PB. I'm going to put a 383 small block in it. What would the best headers for me to get?
Thanks
Old 01-27-2011, 08:56 PM
ericnova72's Avatar
More for Less Racer
Full length, probably 1-5/8" primary tube diameter. Shorty and mid length headers don't perform as well as full length.
Old 01-28-2011, 04:54 AM
sqzbox's Avatar
My pipes are my music
Originally Posted by 1972RedNeck
Howdy,
Thanks
Best in what way? Even a cheap set of long tubes will net better performance
over stock manifolds or shorty's but, the shorty's will be easier to install and route under the truck.
I have a 76 Chevy 4x4 and the biggest problem with any long tube headers as far as I can tell is routing the exhaust from the collectors over and through the transfer case cross member. When I put mine on, I found the collectors were pointing right at the cross member. I had to use flex pipe to go through the cross member because going under would drag the ground off roading. Not the best way to do it but being a budget DIY guy I couldn't afford a custom job from the muffler shop. It's been two yrs. and have had no issues yet with any exhaust leaks. I got a set of Flowtech's for 90 sumthin' bucks from Advance auto parts.
Which Headers for Chevy PU Piston1 Engine 6 06-26-2010 09:00 AM
Will any other headers work on chevy s10 v8 besides swap headers? eric32 Engine 3 01-29-2010 06:39 PM
Chevy Headers. Everett II Engine 2 01-26-2008 09:39 PM
headers for a sbc in a '65 chevy c10? Woogeroo Engine 6 04-22-2006 11:53 PM
48' Chevy Headers pitdad158 Engine 1 08-30-2004 07:28 PM
