the best 400 ci chevy sb - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2007, 05:30 PM
86sdub's Avatar
im am wanting to build a 400 ci small block chevy for my 1986 chevy c-10 and was wondering what type of parts would give me the best engine. i want the motor to be able to run on pump gas as i use the truck for a daily driver. i am going to bore the engine i buy 30 over to make a 406 ci. i would also like to keep bill under $5000. any help would be greatly appericiated.
Old 09-23-2007, 06:30 PM
Need more information like gear ratio, transmission used, tire height, and intended usage of the vehicle...
Old 09-23-2007, 06:58 PM
86sdub's Avatar
3.08 gears (which i would like to keep because it is a daily driver), turbo 350 trans and 28 inch tires. although it will be a daily driver i want to have a good amount of horsepower and torque to have fun with.
Old 09-23-2007, 07:26 PM
86sdub's Avatar
im wanting to build the whole thing myself so tell me if im headed in the right direction. 400ci bored 30 over (406 ci ?) with scat crank and scat 6 in rods, keith black silvolite flat top pistons w/ 3.75 stroke, clevite 77 h series bearings (main rod and cam), moroso 7 qt oil pan with high volume summit pump and pickup, comp cam magnum hydralic 253/253 @ .05 and .525/.525 lift, comp cams high engery hydraulic lifters, comp cams magnum double roller timing chain, comp cams push rods, comp cams magnum roller rockers 1.6, world sportsman II heads 64cc angled plug assembled w/ 200cc intake runners (manley 2.02 int./1.6 exh. valves, 1.250 valve springs, pushrod guildplates,screw-in rocker studs), holley mechanical fuel pump, weiand stealth intake manifold, & holley street avenger 770 cfm carb. im unsure about what kind of water pump to use and if the cam is a good match.
Old 09-23-2007, 07:53 PM
86sdub's Avatar
ok mabey im not trying to build a daily driver but i probably would use it for a daily driver. im wanting a daily driver with a lot of kick. i might take it to the drag strip every once in a while but its main use would be in my truck that i drive everyday. i have been wanting to build an engine for my truck for about a year and i have finally decided what i want to build. now is a good time for me to build the enigine because it is my last year at my tech school and i dont have access to all of the tools and lift anywhere else.
Old 09-23-2007, 08:30 PM
Drewnashty's Avatar
sitis nam accelero
Without getting lower gears maybe like 3.73 I wouldn't get a cam with any more duration than about 230.
I'm in a similar situation so take my word for it. I've got a TH350 with 3.08 in the rear as well in my '76 C10 on 33" tires. With a 226/228 at 0.50 camshaft in my 383 it is kinda lethargic under 3k RPM. I'm currenty gathering parts to put in a posi unit and 4.11 gears and that will really open her up, but I'm also not worried about cruising on the freeway because I'm in the middle of rebuilding a 700R4 to put in the TH350's place.
Old 09-23-2007, 08:44 PM
86sdub's Avatar
thanks for the info. would the 3.73 gears still be good for highway. mpg is important to me because i dont want to have to stop at every gas station i see.
Old 09-23-2007, 09:07 PM
Reuse the stock crank if you can, 5.7 factory rods with ARP bolts would work just fine, keep the cam around 230 degrees @ .050 like previously suggested for a good cruize with 3.08 gears. Compression needs to be about 9.5-1 (dished pistons) for friendly pump gas use. Have the rotating assembly professionally balanced. Check for rod to cam clearance if using 5.7 or 6 inch rods.
Old 09-23-2007, 09:08 PM
3.73 gears would kill your mileage unless you installed an overdrive transmission.
Old 09-23-2007, 09:09 PM
86sdub's Avatar
can anyone tell me if the parts i have listed above would be a good combo for my 406? i think im going to go with a comp cam magnum hydraulic with 224/224 @ .05 and .470/.470 lift so i can keep my 3.08 highway gears. also would the turbo 350 be ok with a 406 or should i upgrade transmissions.
Old 09-24-2007, 02:24 PM
Drewnashty's Avatar
sitis nam accelero
Depends on how fast you want to cruise on the highway, I normally cruise at about 75-80. With 4.10 gears that will be out of the question without an OD tranny.
If you just plan on doing 55-65 MPH 3.73 gears would be a good match up with 28 inch tires. Not to low not to tall
Old 09-25-2007, 08:34 AM
GMC boogie's Avatar
For a fun "daily driver" with the 3.08 gears,I would use the speed pro 12.5cc dish hypers,Scat crank,5.7 rods,72cc dart or RHS heads with 180-200 cc runners and an Isky 270 mega cam.
Mid 70's 400 ci. Junk or not??? 70bird Engine 26 12-18-2005 10:37 AM
Need advice on building 400 chevy roddinron Engine 1 01-24-2005 02:16 PM
Sb Chevy 400 Uneven Feel 2800-3000 Rpm slyshar2 Hotrodding Basics 5 11-18-2003 09:56 PM
Horesower for a 78 Chevy SB 400 sciaretta1250 Engine 3 11-14-2002 09:43 PM
Best Chevy SB Heads dirtlmfan Engine 2 09-16-2002 04:14 PM
