best 454 block to start with
I am looking for a big block for my next build and i was wondering what year or part number is the best block to start out with? Im assuming 4 bolt mains are stronger but i know in some cases like the 400 blocks the 2 bolt is stronger. Im not worried too much about heads because i plan on getting alum heads and roller cam.
Well I plan on making anywhere between 550-650 hp. So I want to for sure then go with a 4 bolt. Any years better than others? What about crank rods and pistons?
You will get lots of opinions on this one, but I am a Gen VI fan myself-why? Factory 4 Bolt Mains, one piece rear main seal, oil galley moved away from the Oil Pan Rail (good for those 4.375" Cranks!), Factory Roller Cam.
Downsides-there aren't as many choices for aftermarket parts for them (but they are plentiful), cranks are different from Gen IV (but Gen V and VI are the same)- |
I can't afford a dart block to be honest as much as I would love to get one. I really would like to get the block that obviously is the strongest and has the most parts available. I also plan on boring it to a 468.
Just sonic test before its even cleaned!!! And good luck! |
as mention, sonic test would be a good idea, but for the most part 60 tho over is will work fine with really no issues not enless the block has had some hard times.. you can goes as much as 125 tho max, but i would not recomend going that far for a street motor, 100 tho maybe just all depends on the sonic test to know if the cylinder walls are thick enough.. you you want to build a 468, thats cool real respectable build.... few more dollars and you can build a 496 with the same 60 over block, just get a cast or cast/steel 4.25 stroke crank, 6.385 rod and some small dome pistons {probe} like these here http://www.ebay.com/itm/Chevy-454-BB...sories&vxp=mtr and you will be set
So with those and a hydraulic roller cam and a good set of heads how much power do you think I'll make?
if you were to build the 496, some minor clearencing will need to be done to the block to clear the counter weights of the crankshaft and rod ends.. 500-600 hp is very possible with a good set of heads and a good cam with well over 550 ft/lbs of torque.. What heads and roller cam you thinking about getting? and intended use? street/strip or racing only or just street?
Yeah that's why I was gonna stick with a 468 because of all the extra machine work for clearances but I'm not positive yet. What roller cam and heads would you suggest? It's gonna be a strip car with maybe a Sunday drive here and there.
The more reading and builds I research the more I'd like to get around 600+hp.
for 600 HP your going to need a serious set of heads and rotating assembly, id consider the 496 route, it will help keep your rpm down which will be easier on the valvetrain.
That said, most guys have never driven a vehicle w/400 hp let alone 600+. It's a whole 'nother game at 600 hp. I'm a little concerned that if clearancing a block for a crank is giving you pause (and this being your first engine build, I'm guessing), you might be in a little over your head. I'm not looking to rain on your parade here, just food for thought. |
| Big Block 454 Gen 5 Block To Be Used In '84 Caprice | jbud94 | Hotrodding Basics | 0 | 09-20-2011 07:52 AM |
| 79 454 pickup not sure where to start | chevyman 454 | General Rodding Tech | 8 | 03-29-2009 03:02 AM |
| 454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 | heathj1 | Engine | 2 | 12-21-2008 10:22 AM |
| Big block 454 and small block match up | boneyard Buick | Engine | 9 | 01-27-2006 07:27 PM |
| Hard to start when hot GMC big block 454 | b5three | Electrical | 8 | 06-05-2003 01:48 PM |
