Best 9" rear disc kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2013, 05:02 PM
Looking for a good, but cost effective 9" rear disc brake kit. It must have parking brakes and not take a pile of screwing around to make fit. Looking to spend around $500.00 so not a "cobbled" together kit. A kit that people have personally used with success would be great!
Old 08-06-2013, 05:44 PM
Wiki Edits: 27
9" brakes
9 inch rears used different axle bearings ends and bolt patterns. If you have what is called the torino end an explorer rear disc brake parts fit. the 5 on 4 1/2 wheel bolt pattern. explorer used an internal drum E brake. Lincoln town car mid 80's used the car wheel pattern but have the lever brake for using the caliper for the E brake. there is more info on ford and mustang forums with other info depending on the car you are swapping.
Old 08-06-2013, 07:07 PM
prostreet6t9's Avatar
Differential/Driveline
Ford Motorsports.. M-2300-G is a nice kit.
Old 08-06-2013, 09:02 PM
Last journal entry: gus`s 40
I used the wilwood bolt on with e-brake and am very happy with them. real easy to install just need to know if you have the large bearing or small and there web site has pictures and dimensions of them all to help
Old 08-06-2013, 09:15 PM
Sorry I should have mentioned, it's a small bearing rear end. The early Fairlane / ranchero rear.
Old 08-06-2013, 10:29 PM
Wiki Edits: 27
old kit
There used to be a kit that used later rotors and the 80's cad eldo calipers with the lever caliper E brake I think the speedway weld on Gm caliper brackets work if some one is not still making the bolt on brackets.
Old 08-07-2013, 05:06 AM
Banned
that is a exployer rear brakes, junkyard is cheaper..
used to be marketed under the SVO name..
I had one..
Old 08-07-2013, 10:42 AM
S10xGN's Avatar
Gotta love a turbo!
From what I've read, the Crown-Vic rear discs are a bolt-on for the small bearing end axle and the Explorer discs (as stated) bolt up to the large bearing ends.
Russ
Old 08-07-2013, 11:20 AM
I had one..
I have the kit on my Camaro now. Around here junkyards are crazy with the prices of the disc brake stuff. It was cheaper to buy it new.
Old 08-07-2013, 12:10 PM
Banned
j/y only buy the backing plate and clapper bracket and maybe the e brake cables..
rotors and clapper new parts store..
think the last time I grabbed a set was 50 bucks,, + rotors and clappers,
much cheaper than the 6-700 bones for the kit
Old 08-07-2013, 01:13 PM
Looks like they're selling in the 400ish range at the moment. But S10xGN is correct they're for large brg housings so it wont work anyway.
Old 08-07-2013, 02:14 PM
Irelands child's Avatar
You can screw around wandering junkyards, crawling under clapped out cars in the mud then rebuilding everything or you can just buy a decent Wilwood setup. You wont get it for $500 - but after you factor in time, gas mileage and repair parts - you still have a bunch of bucks tied up and a rebuilt brake setup. This is what I have on my '57 Ford 9" small bearing rear end complete with everything NEW including the 11.75 brake disk :
The latest version has an Explorer integral e-brake which is nice, but this arrangement does work nicely. Oh and those black socket head cap screws - they like to rust so I have since replaced them with shiny ARPs
Irelands child
Old 08-07-2013, 06:17 PM
I was kind of thinking the same thing. I have a set of wrecker crown vic rear brakes, but will need rotors, calipers, hoses, and make up some kind of e brake arrangement. And if memory serves me correct I'll need to flip the backing plate on the DR SD to get the e cable to pull properly, make spacers, buy parts, and hop it all works well. Looking more for a proven kit for a small bearing ford. I like the willwoods. Anyone use a SSBC kit????
Old 08-07-2013, 08:40 PM
Moser Engineering makes a nice "economy" rear disc setup with E/brake ,around 400-450.00 use them at my rear end shop,nice kit.
Old 08-07-2013, 09:07 PM
Not sure if I missed it, but I did not see small bearing ends available.
69 Camaro Rear Disc Brake kit?? kieferrestoration Suspension - Brakes - Steering 2 04-02-2010 07:43 PM
Where can I fnd a disc brake kit for jaguar rear end Larry Tyner Suspension - Brakes - Steering 8 01-08-2010 02:50 PM
8" Ford Rear Disc's kwhizz Suspension - Brakes - Steering 3 07-02-2009 11:21 PM
9" disc brake conversion kit ? 56f100 Suspension - Brakes - Steering 2 06-23-2008 09:57 PM
What is the Best Rear Disc conversion Kit Not A T 25 Suspension - Brakes - Steering 6 10-09-2007 11:25 PM
