Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best adhesive on intake manifold gasket???
Old 01-30-2007, 06:31 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
If you use high quality gaskets you do not need any gasket sealer or cement. FelPro especialy has sealent already on the gaskets around the water ports. The only place I would even consider using anything would be at the four corners where the front and rear gaskets meet the side gaskets, then it is only a dab at best.
Vince
