Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best adhesive on intake manifold gasket???
Old 01-30-2007, 07:02 AM
pepi's Avatar
pepi pepi is offline
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Originally Posted by 302/Z28
If you use high quality gaskets you do not need any gasket sealer or cement. FelPro especialy has sealent already on the gaskets around the water ports. The only place I would even consider using anything would be at the four corners where the front and rear gaskets meet the side gaskets, then it is only a dab at best.
Vince
Totally agree!! a good indication is the FACT that the factory does not use the goops.
