Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best adhesive on intake manifold gasket???
Old 01-30-2007, 07:59 PM
GearJamminHero GearJamminHero is offline
4cyl Pentastar Fanatic
Originally Posted by 1ownerT
When the intake bolts go through the intake into the head at an angle, you cannot install dowels...there is no way to set the intake over them. If the bolts were to install vertical...then it would be possible.
You could use something a bit more flexible and thin, perhaps pieces of coat hanger or something similiar? Stick it through the corner holes in the manifold, through the gasket and then to the heads. Toss a couple of fasteners into the center pieces then pull the wires out, may make things easier.
