Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best adhesive for v-cuts in foam?
Old 03-22-2013, 10:53 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
The problem may be more with your technique than the glue you are using. Are you scuffing the closed cell foam with sandpaper or a Scotch Brite pad? Are you spraying the adhesive on the foam and the vinyl and letting it dry completely before mating the two parts? If you want to use an aerosol, the Performance is not bad, and 3-M Super Trim adhesive #08090 is good too, but it is expensive. BTW, 3-M 77 and 3-M 74 just do not work for automotive work.
