Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best adhesive for v-cuts in foam?
Old 03-22-2013, 12:49 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Better too aggressive than not agressive enough. The contact adhesive has to be completely dry so that it is just the tiniest bit tacky and applied to both pieces, the vinyl and the closed cell foam or it just won't stick. If you wait too long, and the glue is too dry, all you have to do is spray it again to re-activate it. If you want to use the DAP Top and Trim adhesive, it can be applied with a brush, you don't need to spray it.
