Best bang for the buck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2003, 01:36 PM
Muscle car fan
Here is the setup so far
74 Ford Gran Torino (3700lbs)
8.8:1 351W infront of a c6 trans
cleaned up stock heads
3.56 rear gears
edelbrock rpm air gap intake
1" 4 hole carb spacer
670cfm Holley
Flowtech Long Tube headers
summit cam (@ .050 in. cam lift: 204/214 .448"/.472" lsa 112 degrees)
what would be the best bang for the buck upgrade next?
better ignition?
valvetrain?
changing any of the components i allready have to different ones?
any input would be wonderful
Thanks
'74 Gran Torino Project
351W, c6 trans, 9"
Old 12-28-2003, 01:38 PM
lluciano77's Avatar
Better heads. Even cleaned up Ford heads don't flow well.
More compression. You are at a smog compression ratio now. Your gas mileage and power are suffering.
Old 12-28-2003, 03:05 PM
stepside454's Avatar
heads might be good....or a good Ignition upgrade
Old 12-28-2003, 03:16 PM
poncho62's Avatar
Wiki Edits: 5
Like they say, if you can't breath, you won't live long.....HEADS
Old 12-28-2003, 03:19 PM
Muscle car fan
MSD Digital 6+ is what i was thinking
what else would i need to run it, a magnetic crank trigger, new disy? what kind of coil should i run?
351W, c6 trans, 9"
Old 12-28-2003, 03:21 PM
Steve karch's Avatar
A cold air induction from Ram Air Systems from Hamilton, Ontario. The cost is something like $100.00 US.
Old 12-28-2003, 03:35 PM
Muscle car fan
i have a cowl hood, and it sucks cold air in though the hood
351W, c6 trans, 9"
Old 12-28-2003, 03:47 PM
That'll do the trick. Heads are next then. Sportsman ll would work well.
