Best BBC Block & Max Over-Sized Bore? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2012, 08:18 PM
I currently have a BBC Block casting # 361959. Is this block considered one of the preferred casting numbers to build and what would be the maximum over-sized bore for this block?
Old 05-16-2012, 09:53 AM
1971BB427's Avatar
Your casting number is a '73-'85 BBC 454 car/truck motor. Pretty common and standard engine. Maximum over bore is not what I'd consider, as it leaves you nothing in the future. Some 454's have been bored .125", but each has to be looked at for core shift, or other indications of a possibble issue when going that far.
Most people would consider .060" as a safe maximum that doesn't require any special work to determine cyl. wall thickness. I personally like to stick with .040" max, as it leaves me another safe step if I ever need it.
Old 05-16-2012, 04:22 PM
Thanks for your follow up. I have heard some casting number blocks are are better than others so I was curious if this was one of the better blocks. Thanks Again!
Spread bore manifold & square bore carb? 383SBC Engine 2 04-09-2012 09:21 PM
bbc 402 max bore and stroke dre1984 Engine 3 03-23-2010 01:16 AM
max bore of 396 bopedersen Engine 4 02-24-2008 05:39 AM
Max bore Jzarczyn Engine 11 06-24-2004 03:01 PM
