Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best bet?
Thread: best bet?
Old 11-27-2005, 09:06 AM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
Rebuildable 340 engines are getting tough to come by, you better have deep pockets if you want one. If you want more power go with more cubes and get a 360, they are a dime a dozen. The 360 can be stroked up to 408 or even larger cubes. A small block doesn't have the weight of a 440 and fits alot better in A Bodied cars. Headers would be a nightmare with a 440, as would trying to have power steering. If your starter ever goes out on a 440 powered Dart, you will not be a very happy camper when changing it. On a 440 powered Dart you will have to beef up the front end, use a 727 trans and run at a minimum a 8 3/4 or Dana 60 rearend. I was thinking about going the big block route on my 72 Dart but came to this conclusion, but this is just me.
