Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best bet?
Thread: best bet?
Old 11-27-2005, 04:57 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by cuda66
I have a 66 barracuda and I have done the swap that you are talking about. I spent the money on the 340. But I tripped across a 70 340 short block that needed to be rebuilt for about 400.00. the problem that you will run into wiht the 360 is that it is an externally balenced which means that you will not be able to use the transmission that you are currently using. You will not only have to buy a motor you will need a different transmission. I went from a 273 to a 318 to a 340. If you do it right you can get about 350-400 hp out of that 318 and people would make fun of you untill you roasted them on the track. Joel
You say that you have to change the ENTIRE transmission??? Wow I thought sure somebody made parts for Mopars......
