Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best bet?
Thread: best bet?
Old 11-27-2005, 08:54 PM
onebadmerc's Avatar
onebadmerc onebadmerc is offline
I need a bucket of arc sparks
Mopar Performance sells the weights needed to balance out the ring gear/converter so you can use the tranny that is in your car. Most likely a 318 will have a 904 behind it if it is a automatic, but I have seen some 727's behind 318 engines. The problem you will have is the 360's drivers side motor mount is different from the 273-318-340 engines. The 360's oil pan is also different than the 273-318-340 engine, but most likely it will be a center sump unless it came out of a truck or RV. This should be the only problems you run into from swapping a 318 to a 360.
