Which is best? Blast or dip?
Hi,
My project is a 64 GTO that had sat outside for 12 years, partially disassembled. Although where I live (western CO) is a dry climate, there is still a lot of what I call surface rust all over the interior of the roof, doors, etc., as well as a lot of the outside, of course. I did a search on this board and have read about chemical or acid dipping and electro priming, etc., which sounds great! I've also done other projects where I've sandblasted or used Rust-Mort (which chemically treats the rust and turns the surface to "primer" that you can paint over) on spot rust. In this case, though, I'd probably have to take a spray gun and apply a LOT of Rust-Mort on like a primer to get ALL the rust on this car. Plus, I'm not sure if I'll be able to get all the rust on the interior if I do it this way and then try to paint over it. I only want to do this ONCE and then not worry about it again, until, say, after I die. Do I bite the bullet, wait in line a year, transport the car and frame over a thousand miles and pay around 6K to get it dipped and primed? Or, is how I mentioned above using Rust-Mort, elbow grease, a spray gun, and hoping for the best a viable enough alternative? Or, better yet, does anyone have any other ideas? I'm open... Thanks... |
Rust removal
Here is the thread I have found that I can buy all the equipment and tools needed do the job and throw it all away and still be less money than sending the car out for prep..
One tip is to do a section at a time..and at the end of the day spray the epoxy on the cleaned area..doing it that way saves on all the flash rust and do overs..And I second the SPI..that made me a better painter.. Sam
Thanks.
Thanks, Fellas,
I appreciate the feedback. I just want to make sure I can get it done the right way, ya' know? I've pretty much done the rust removal with the elbow grease, naval jelly, etc. on other projects, but when you hear about how easy a chemical dip and electro priming is (of course, you PAY for that privilege...), it sounds sooo enticing. Thanks again, Chris |
| Dip Stick Reading | 70bird | Engine | 10 | 06-08-2006 11:21 PM |
| To dip, or not to dip?? | warren1328 | Body - Exterior | 5 | 05-14-2006 10:38 PM |
| bead blast guns and nozzles | powerrodsmike | Garage - Tools | 1 | 11-18-2005 09:03 PM |
| to dip or not to dip? | mopar72 | Body - Exterior | 13 | 12-21-2004 08:44 PM |
| To dip or not to dip? | Great '48 Bow Tie | Body - Exterior | 5 | 07-24-2002 07:53 AM |
