Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best brake pads for Mustang II ?
Old 10-29-2007, 09:16 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Several companies sell the basic swap kit, with just the necessary bracket and hardware. The calipers that are used most often come off of a 78-81(84?later?) GM midsize, like a camaro, or monte. those years usually have the smaller "metric" caliper.
The earlier 69-77 GM midsize car caliper is larger, with a bigger piston, mounting hole spacing and pad..
Scarebird is another good place to find a bracket/ hardware set.
Later, mikey
BE different....ACT normal.
