1) Need to know year of the truck? 2) Year of the engine if it's different from the chassis? 3) Year of the block if it's different from the Vortec heads you reference those being 1996 and newer items for production? 4) Which transmission? 5) Does it need to smog? There are a lot of changes year to year as to how the systems work and relate. Change difficulty is variable by year, and the cam is usually a large change, especially if when it comes to Manifold Absolute Pressure managed fuel injection. This can get expensive making system and computer chip changes, so it's necessary to have answers to the first questions to even get started. Bogie |
Ok, teh truck is a 91 chevy pickup. the engine details will be:
350 4 bolt main 010 block. Not sure what years these were from. early 70s? or I have a 4 bolt 350 block from a 82 dumptruck either will be bored at least 30 over stock crank cut .010 Probably stock rods stock replacement cast flat top pistons stock 062 vortec heads Probably stock manifolds from the 91 truck No smog in my area. Might keep a cat on it so the exhaust does not smell. 700R4 stock trans from the 91. |
What do u know about the thumper cams a buddy of mine can't get over how they add so much hp
What I do know is this thread is 3 years old. I also know thumper cams are fad cams, all bark and no bite. They're designed to make a engine hit a heavy lope exhaust lick and sound good, they aren't so much on power development.
Other high performance cams lope at idle as well as long as the combo is tuned right. |
Cam
You did not explain how much the truck weights and I don't know if you are in the trades and carry tools or anything like that.
I would look for a cam that would increase your low end because that is what most trucks need. I have an 1986 Chevrolet Van that we put a 350 engine in and the motor was 30 over which makes it a 358ci and with the right Comp Cam it pulls hard and get the van full of tools up to speed fast. Jimbo |
| What engine is in my truck? | canine1566 | Engine | 9 | 10-26-2010 02:06 AM |
| 350 SBC marine engine sluggish? | daeble | Engine | 17 | 02-21-2010 05:26 AM |
| Engine rebuild questions - SBC - Central MD | CuttyGMachine | Engine | 6 | 07-17-2009 11:34 AM |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Basics about 400 SBC engine | MacGyver | Hotrodding Basics | 5 | 03-26-2008 03:04 AM |
