Best cam size for my 327 with AFR 180cc heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 11:32 PM
I have a 327 currently with vortec heads. I plan on putting on AFR's 180cc Eliminator Street heads and swapping out the cam for a bigger one. I plan on keeping the compression under 10:1, and was hoping for 400 hp or more. Just curious as to which cams you might recommend.
Old 02-29-2012, 12:30 AM
The car is a 1967 camaro, 3.50 gears and a 700r4 tranny, 9 inch rear, I don't know which torque converter because the guy I bought the car from knew very little mechanical info on the car.
I'm assuming now that you've read my other post containing engine specs too. Also, I had read that stock vortec heads could only handle up to around .450 or .460 lift cams.
On the pistons, I was just assuming they were flat tops because once again, he knew hardly any mechanical info on the engine, but they could just as well be domed pistons. I just haven't got around to nor did I plan to tear the engine down unless I were to swap heads and a cam. The engine is a fresh rebuild also, according to the guy it was rebuilt 2 years ago.
Also, I don't see this engine as having that low of compression as it needs 91 octane and pings if you jump into it too quick, although I do have the ignition timing advanced and I haven't checked the cam timing but he could've had it advanced also.
Old 02-29-2012, 02:33 AM
With my current setup, should I use the rpm over the eps?
180cc or 200cc intake runn141 Engine 22 02-18-2012 04:19 PM
Wanted Afr 180cc 0911 Chevystr383 Engine 2 09-02-2010 11:37 AM
200cc heads or 180cc? jak327 Engine 19 02-25-2009 06:23 PM
size of sbc 305 heads greyghost Engine 5 10-05-2008 02:46 AM
AFR heads, 180cc or 195cc Lthompson Engine 15 11-03-2004 10:58 PM
