Originally Posted by Parisienne70
Hi,
I have a Malibu 1977, Daily driving and some race for a pleasure
My setup is
Cylinder head 041 with 1.94 valve stock
Block 350 with original dished piston
Intake edelbrock performer
Carburator edelbrock 600 cfm
Turbo 350 with shift kit and a new stall converter
gear posi 3.42
What best camshaft for this setup ???
I see on ebay a aluminium radiator is a best choice ????
And what stall converter i need ???
Thank you for your help
Éric
CC has a program called Cam Quest. You put in a bunch of specs, and they give you a bunch of recommendations.
Whatda you know! I spec'd my own cam, for my engine and use. Got around to running the CC program and SHAZAAM! they recommend the same cam I picked out.
Call the cam companies for advice, they have seen it all and can offer advice on your build/use.
I would trust the cam companies recommendations, unless you are smart enough to do it your self, over Jethro down at the drive-in only because, if the company gives you a bad choice you can bad mouth them on the net (and they know it). Who gives a ******* if you bad mouth Jethro???
BTW, CC XE274 hydraulic flat tappet in a strictly street 383 with 10.30 static CR, Edel RPM Q-Jet intake, reworked Q-Jet carb, 1 5/8" long tube headers-true duals, TF 23* 195 cc heads in a 3300 #, with my fat *** in it, C3 'Vette with a 3.36 rear and 4 speed. Stock cold air induction WITHOUT a fashionable K&N. Accel HEI, 34* total timing running on 89 octane pump gas.
