Best car wash soap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2003, 05:24 AM
roys63's Avatar
Best car wash soap?
What is the best soap to stop water spots from hard water?
Old 07-20-2003, 05:09 PM
302 Z28's Avatar
Soap is not going to prevent water spots, I dont care what the advertisement says. The only way to prevent water spots is to have a waxed surface first. Wash it, rinse as soon a possible and dry as quickly as possible.
Vince
Old 07-22-2003, 09:29 AM
Phyrkrakr's Avatar
Poor Student
The best thing I've found to keep the water spots off is to dry the car by hand. I hose the whole thing down to rinse the soap off, then let it dry in the sun for just a little while. Once it's almost dry, wipe away any standing water or streams of water that come off of a roof line, trunk lid, etc. If necessary, use one damp rag and one dry one to touch up any spots.
Old 07-22-2003, 11:54 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I do mine in the shade. Hose it down, wash it, hose it down, shammy all the water off, wet and wring the wax applicator, do a light coat of Mothers Wax (one section at a time - waxing then wiping off). When done, I hose down again and shammy cloth again -- cold water hardens the wax.
Alan
54 Chevy Pickup
Old 07-22-2003, 04:36 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I used to get water spots real bad, no matter what I did. But then I started rinsing my car with filtered water (which was a pain), and they stopped. I had to run a hose from my kitchen sink to the front yard and the water pressure sucked.
Old 07-24-2003, 03:10 PM
Dave E Shank's Avatar
HEY ROY: Your are right, the water spots are mineral deposits in hard water. You might try a couple drops of fabric softner, should not take much. ...GOOD LUCK....DAVE
Old 07-24-2003, 08:15 PM
akm akm is offline
ajax
Old 07-25-2003, 09:34 AM
Kevin45's Avatar
Just one of the guys
check this out http://www.drivewerks.com/techarticl...s_corner-1.htm i never use a chamois. i have always used big bath towels that have been washed with no fabric softener. something else is to use cloth diapers for the windows. wash in hot with no softener and when you wash the windows they will leave no streaks.
kevin
Old 08-25-2006, 12:25 PM
New Member
Cheap airline tickets from all major internet suppliers
*********************************discount ********* and cheap *******, ******, consolidator*****, discount ******, *****, *****, Last minute **********.
Old 08-25-2006, 01:09 PM
35WINDOW's Avatar
Last journal entry: Engine!
I used to sell a lot of Watercraft (Jet Ski's and the like), and there was a Product out there that was designed to keep the water spots off of the Boats and such after you got it out of the water. I've used it and it works very well, but I can't think of the name-
Old 08-25-2006, 01:24 PM
poncho62's Avatar
Wiki Edits: 5
If you have a water softener, that is the way to go...........................However, most outside taps are plumbed in before the water softener.
Ontario Rodders
Old 08-31-2006, 11:07 PM
mitmaks's Avatar
Last journal entry: Grille
which wax is everyone using?
Old 09-01-2006, 12:07 AM
watter spot cure
move to vancouver or any other coastal city in b.c.,the watter is soft and no streaks after the wash
Old 09-01-2006, 07:13 AM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
I use Meguires, that new Tech stuff, of course it was asked so I will not remember the exact name.
As far as wax, I use Meguires Cleaner/Wax on my truck and wifes SUV. The car I use a 3M polish.
Old 09-01-2006, 10:10 PM
roger1's Avatar
1. Wash with any car-wash soap and rinse the car in the shade.
2. Immediately use an electric weed blower to blow off most of the water.
3. Use a large high-quality chamois to do a final wipe-down.
