Best carb for ease of starting - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-26-2010, 08:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pig rich can be as simple of a fix as using a can of carb cleaner (use can directions), paying special attention to the air bleeds located in the air horn and just inside of the primary throttle bore.
Cost you < $3.00 to see.
The Q-jet does often suffer from leaking main wells. If yours is doing this, hold the throttle WFO, w/o pumping it- just mat the throttle and crank it up. Obviously, let off when it catches!
  #17 (permalink)
Old 08-26-2010, 07:58 PM
bigdog7373's Avatar
Of course it's fast
It never catches that's why i ordered the edelbrock, because i'm tired of fighting a losing battle. I just want to drive the car but i cant even make it down the driveway without it dying.
  #18 (permalink)
Old 08-26-2010, 08:45 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
The edelbrock 1405 is a manual choke and the 1406 is the same carb with an electric choke . I put the electric choke kit on my 1405 and it works great .
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
Too much carb? KNanthrup Engine 5 09-03-2005 06:47 PM
Carb Jetting Starting Point camaro 68 Engine 3 04-13-2004 03:55 PM
