Best carb spacer style Edelbrock carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2011, 11:38 PM
truckboy61's Avatar
Im going to buy a 800 cfm thunder series carb for my 454 which has stealth dual plane intake. What style spacer if any is best?
Old 07-24-2011, 07:59 AM
Well a four hole spacer is good for more bottom end and mid range torque and using a open spacer will give less on bottom end but will give more in the top end range of things but it will also lean your carb out on bottom end as well. Some times they make a difference and sometimes they don't. I tired both on my engine and a four hole was excellent for me as I need bottom end grunt over top end. Since you have a dual plane intake I would go with a four hole.
Old 07-24-2011, 10:18 AM
truckboy61's Avatar
Thankd for info will do
Dual Plane Carb Spacer Edelbrock 8714, 8715 JohnSerb Engine 11 05-05-2011 07:58 AM
Which carb spacer? Greg T Engine 3 08-12-2010 07:40 AM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
Carb install, spacer or no spacer? MM in NM Engine 3 03-17-2006 07:23 PM
carb spacer sah Engine 14 08-26-2004 08:39 AM
