Ditto--------------------! |
times 3.......
The question was what was the best cfm carb for balance of power and economy and in that case you can`t beat a Quadrajet. The small primary`s are almost sensitive as fuel injection, give great throttle response with excellant economy. When performance is needed the massive secondary`s are there to give it all the flow it needs. Most Quadrajets flow 750 cfm, but it`s a air dam carb so it only gives what the engine demands. Sure, a 600 cfm carb would work, as would a 750. But his engine is stock, and he wants performance and economy and for a application like that the Quadrajet is the best carb I know of. I`ve used holley`s, demons, edelbrocks. But I always go back to Quadrajets.
Go to the Holley website and use the Interactive Carb Selector at the middle top of page, first off enter your CID.
" What is the best CFM for a balance of power and fuel economy?" ok? last time i check cfm stood for cubic feet per minute, not brand name. i never said go buy a holley or a edelbrock. i dont even have anything against quadrajets. he just asked for a good cfm to run on a 350 for power and economy. hence the 600 is as strong as a 750 (theres your power), its also inherent that the 600 will have better economy since it is a smaller carb. i do believe my self that the quadrajet's design would probably provide better economy in most situations, but to just tell him to buy a quadrajet isn't really answering his question. thats like if somebody asked what size tire goes on an 87 Mazda truck, and i said a b.f. Goodrich.
i like the AFB . its economical. super easy to work on. the secondaries have mechanical butterflies. there is an adjustable spring air door that supply resistance for the carb to pull off from. 3 holes for accelerator pump timmings. the step rod metering system is breeze to getting tune. works over long perios of time. edelbrock makes a thunder series that is nice.
Lookit, I didn`t reply out of having a pissing contest over this. He said stock, how many millions of GM vehicles came stock with Quadrajets? V6`s came with Q-jets knowing it would never use 750 of flow but thats the beauty of a air dam carb. In any stock application CFM pretty much doesn`t matter, you can bolt a 1 barrell on it and it would work one in the same. So I answered his Question by saying a Quadrajet and many agreed. It was the simplest answer without getting technical about it. Who wants to get technical over a stock engine?
Whoaa, guys... chill out. First of all, he didn't say if his "stock" 350 was 140 hp or 300 hp, so the answer could be 350 cfm or 600 cfm.
He asks a generic question, he'll get a generic answer. One of the reasons we all said Qjet was because (in addition to being a great carb) the way it meters flow makes it work over a wide variety of applications. So, to say "you need 600 cfm" is pretty ridiculous since we don't know WHICH stock 350 he has. Here's the math, assuming you have one of the millions of stock 350s that were in the 175-hp territory. It probably has 7.8:1 or 8.0:1 compression, wheezer heads that wimp out by 4500 rpm, and a sub-200-degree cam. So, a 350ci engine at 4500 RPMs and 80% VE consumes exactly 364.58 CFMs. If you really want economy, get a 2bbl, or a Qjet. You won't give up any power, and you just might improve torque, throttle response, and almost certainly will improve MPG. Keep in mind that 4-bbl carbs were an old trick to get more power back when the largest 2bbl carb you could get was about 290 cfm, and the largest 4-bbl was 385 cfm. The need for 4bbls on a stock 350 is ridiculous, but the Qjet's primaries are just about ideal for anything. |
| Holley 4777 carb. questions. | TVR383 | Engine | 16 | 07-05-2009 02:23 PM |
| Lean problems with BG Speed Demon carb | Sixtyninemercury | Engine | 29 | 04-16-2008 08:02 AM |
| carb cfm question | johnnyblaze | Engine | 10 | 02-29-2008 08:47 PM |
| What vehicles come with about 400 CFM 4BBL carb? | sizemoremk | Engine | 13 | 07-14-2003 03:05 AM |
| carb selection 4 in mind, demon holley or edelbrock? | Jared | Engine | 6 | 06-18-2003 12:55 AM |
