best cheap chevy to drop a sb into - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-16-2003, 04:52 PM
mikeweyman's Avatar
Last journal entry: 2 years later
chevy s-10 trucks are light and can accept a sbc rather easily. if you get rid of the groove on the side,drop it down a little, some mid seventies turbine rims, some flares ,and a scoop.this will be cost effective, and very respectable where ricers are concerned. mike
  #17 (permalink)
Old 10-16-2003, 09:15 PM
New Member
GREMLIN
  #18 (permalink)
Old 10-17-2003, 12:56 PM
V8 S-10's Avatar
v8s10.org
<-----S10 Cheap, plentiful and light.
  #19 (permalink)
Old 10-17-2003, 02:38 PM
Last journal entry: rear suspension
Awwwweee Yeaaahhh! That is an awesome project truck V8-S-10. Was the transplant difficult ? Did you use a kit? How about the rest of the drivetrain? Gosh; I could ask questions all day! Looks real close with the radiator. Have you seen the "BeCool" products? No need for the belt driven fan. They use a custom shroud with electric fans mounted on a custom aluminum radiator. Engine runs much cooler and even a bit of a horsepower gain due to the absence of resistance. Just a thought
  #20 (permalink)
Old 10-17-2003, 04:13 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I to like the Gremlin idea because of.....Well you know. Anyway, a Chevette is way bad also. I had a V8 chevette some ime ago as the older members recall. It was fast!!! I just bought the Gremlin to pro street it and decided to stick with that idea. Check it out in my album. Just click on my Gremlin avatar. HG
  #21 (permalink)
Old 10-18-2003, 11:23 PM
matt_ramsey's Avatar
Your Basic Moron
How hard was the chevette V8 conversion... what did the rear axles come out of? These cars are cheap EVERYWHERE... is there anything else I should know about while I'm still in the planning stages?
  #22 (permalink)
Old 10-20-2003, 05:39 PM
I luckily bought it almost finished. I used stock rears and replaced em when they broke, but I think an S-10 rear is a close fit. The firewall was notched a bit for the distributor and there was a (Knuckle, joint, ?) put on the steering shaft. Its just a lot of measuring and mocking up, but at 2,080 lbs or so, It was a wicked ride.
If your interested, I'll try and find this old Chevette, V8 swap forum. Let me Know. HG
  #23 (permalink)
Old 10-21-2003, 09:04 AM
Your Basic Moron
I did find a few sites on the subject and you're right, Hemmie, it does look like a lot of customization... probably too much for a 2-month "summer project"
especially for a guy like me with practically no fabrication experience.
Maybe I will get lucky and score a Nova by spring's end...
thanks for your help guys!
