I use a lot of steering out of 98-2001 camaros. A lot of those cars had floor shifters so they are clean and you can cut the housing down and re tack it whatever length you need. I also use the short ones out of 89-92 gm vans. they are just right for coupes and have shifter and indicator on them. also standard gm spline so you can either adapt or buy an adapter for virtually any steering wheel. I recently used a banjo wheel out of a mg on a 34 ford...It looked great! Both have standard d shafts on the end and it is easy to get hookup connectors also....
