Best Chevy van steering column? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-17-2011, 05:36 AM
gm steering column
I missed a deal on an early 70 s gm tilt with shift at Charlotte,,,,got off my butt,,found 2 caddy columns ,early 70s,,and they have the scope deal,,paid about the same for those,as the guy wanted for one at Charkotte,,,,,do I need 2,,,why not,,,seems to be the right length,will install in my 69 SS elcamino
  #17 (permalink)
Old 11-17-2011, 09:59 AM
Mutt's37Buick's Avatar
Thanks for the advice.
1) Can I measure the old steering column in the vehicle, or do I need to remove?
2) Does anyone know how long the column should be for a 1937 Buick Roadmaster?
3) Are there tilt columns from 70's Chevy trucks that would work as well?
Thanks
  #18 (permalink)
Old 11-19-2011, 08:55 PM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
column
I use a lot of steering out of 98-2001 camaros. A lot of those cars had floor shifters so they are clean and you can cut the housing down and re tack it whatever length you need. I also use the short ones out of 89-92 gm vans. they are just right for coupes and have shifter and indicator on them. also standard gm spline so you can either adapt or buy an adapter for virtually any steering wheel. I recently used a banjo wheel out of a mg on a 34 ford...It looked great! Both have standard d shafts on the end and it is easy to get hookup connectors also....
  #19 (permalink)
Old 11-20-2011, 01:34 PM
Thanks for the info.
  #20 (permalink)
Old 05-07-2012, 03:50 PM
Been a while since I started this thread, but have some questions related to the steering column I ended up with.
Bought a donor car and will be using the tilt steering column from '95 Buick Roadmaster.
1) Does anyone know if there is an adapter available that will allow my '37 Roadmaster steering wheel to be used with it (see picture) ?
2) If not , then what are my options for a vintage looking steering wheel?
Thanks
Mutt
  #21 (permalink)
Old 05-07-2012, 04:07 PM
adaptor
I usually get a grant wheel adapter that fits on your column. make a plate out of pretty thick steel and drill it so that it matches adapter. find the exact center and weld the spline for the old wheel on to it keeping it as short as possible. the adapter kit comes with a steel cup that you use to hide the plate. bolt it together.....
Wiring a 60s Chevy steering column C.Harrison Electrical 4 11-03-2010 07:49 PM
84 chevy c-10 steering column kunklekustoms Suspension - Brakes - Steering 3 12-29-2007 11:43 PM
identify chevy steering column GMR Suspension - Brakes - Steering 1 03-09-2007 11:50 PM
55 chevy steering column for 605 box r morales Suspension - Brakes - Steering 5 01-03-2005 08:42 PM
39 Chevy Steering Column Beenaway2long Suspension - Brakes - Steering 6 01-08-2004 04:52 PM
