Best Clears for adding pearl or candy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 06:24 PM
HotrodLincoln's Avatar
Hammer King
Last journal entry: paint job
A few questions
First:
I am looking for some general info. I know a lot of folks on this forum use the SPI products. That is why I gave them a try and I am very pleased with the results. This was a basic clear over base with the "mid solids" clear over PPG DBC base.
Now, I want to do some pearl in clear, and some kandy concentrates.
Best clear to use? Mid-solid, high solid, universal?
Question two:
Any one use the water based Createx airbrush paints? I have a lot of good results with these on non-automotive projects. They are easy to use (but take a long time to dry).
Can a regular Automotive clear go over these paints?
I am turning to the experts here. Thank you for your help.
Old 09-19-2005, 06:50 PM
mrcleanr6's Avatar
question one: i prefer to mix pearls and sometimes candy into a clear basecoat (intercoat clear, hok sg100). i mix candys into this when doing graphics but on an overall i prefer to use the urethane hok line. i wouldn't mix concentrates into a regular clear for this because of the amount of coats needed. hok's uk line with the ku100 is very forgiving when it comes to runs and for some reason handles the 7 coats of candy + 2 coats of clear in one session without problems. spi stuff is great but not sure about safely spraying 9 coats in one session.
question2: i have used the createx stuff and yes you can clear over it but it really is crap. you just cant get the detail with it that you can with the automotive paints. the createx is acrylic base and clogs the crap out of the airbrush and is problematic. automotive is so much smoother and precise.
Old 09-20-2005, 12:14 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Using a pearl is fine in a clear as long as you have it right on the mix and only requires 2 coats to cover right and then the last coat being straight clear. Color sanding pearl which would be in the top layer can screw up the effect is why you shoot a straight clear last has been my experience.
KK Koncentrait HAS to be built up in layers to achieve the desired color,so an inter coat clear or a base paint "binder" is necessary as these are reduced like base paint and are thin,multiple layers compaired to a standard clear coat.
I have not used the water paint but know several who have and the opinion is mixed on how well they do. Using a hair dryer will speed up the dry time as these really need "heat setting" to adhere properly. Once properly dried,any clear coat can be applied over them as far as I know but I'd check with BarryK here on the SPI clear.
SG 100 HOK intercoat clear, any tips for dry pearl? wreckedGTI Body - Exterior 10 08-01-2005 07:04 PM
Sag in last coat of pearl BondoKing Body - Exterior 6 05-14-2005 03:33 PM
question on candy paint CHOPPERzRULeALL Introduce Yourself 2 08-22-2004 08:46 PM
pearl's in paint 2wld4u Body - Exterior 8 10-18-2003 08:26 AM
Candy.... DigitalW Body - Exterior 3 06-29-2003 02:30 PM
