Best coil to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 10:58 AM
Best coil to use?
Hello, I am thinking of replacing my coil on my sbc 350 mallory hei distributor, and was curious what is the rule for getting the best coil. I also have the msd ignition box I have not installed yet, so just looking for the best combination of parts for max performance. Thanks.
Old 09-05-2009, 06:27 AM
sqzbox's Avatar
My pipes are my music
msd
install the msd and use the complete package. Don't mix-and-match parts or your just asking for problems. After you install it, be sure to read your plugs
for correct heat range. Have you tried the new E-85 spark plugs yet? I've heard nothing bad about them yet. Expensive, yes but, worth the money.
You can put the best ignition on but if the plugs ain't right, your just wasting money. If you want to keep the mallory, use all mallory components (rule-of-thumb).
Old 09-06-2009, 09:31 AM
rem.............
Old 09-06-2009, 03:40 PM
302 Z28's Avatar
Just about any brand other than Accell
Vince
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
1991 olds 88 3800 engine coil pack fumplet Engine 28 07-19-2007 12:39 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 03:36 PM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 12:07 PM
