best combo for 300hp 305 engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2011, 11:24 PM
jmaine83's Avatar
whats the best combo for 300hp 305 engine?
Crane 272 cam 216/216 @0.50 454 lift,edelbrock perfomer 416's stock heads with z28 springs double roller timing chain 600 cfm holley carb.... maybe 300hp?
Old 08-19-2011, 04:50 PM
bigdog7373's Avatar
Of course it's fast
Need to do a little work on the heads. Bigger valves and some port work.
Old 08-19-2011, 05:49 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
I have a 305(14010203) block with edelbrock performer cam and lifters matching eddy intake, eddy 600 cfm carb stock 601 heads attached to a 700r4 dynoed at 240hp/230tq. Pretty fun for me and less than 1000 bucks to do
Old 08-19-2011, 06:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You started out with wanting to know how to build a 370hp 305 then went to a 300hp 265 and now you're at a 300hp 305. Why not get a dime a dozen 350 out of a junkyard and and build that? You can build a very mild 350 at 300 hp.
Old 08-19-2011, 08:28 PM
cool rockin daddy's Avatar
How many threads you going to start about this mega HP 305?
Old 08-20-2011, 03:25 PM
badknuckles's Avatar
you talkin to me?
Put in a350 and put a305 emblem on the air cleaner.
Old 08-20-2011, 08:24 PM
jmaine83's Avatar
i never wanted to build a 300 hp 265 just wanted to know how to get 300 hp outta a 305 i know hotrodders had the answer......guess not....thanks for replys guys
Old 08-20-2011, 09:24 PM
Tbird's Avatar
300 Horsepower 305 Chevy V-8
1) Set of stock Vortec heads with upgraded valve springs
2) Edelbrock Performer RPM intake and cam
3) 650 cfm 4 barrel carb
4) Headers
Old 08-21-2011, 09:59 AM
jmaine83's Avatar
thanks tbird
Old 08-21-2011, 02:17 PM
you talkin to me?
i think what is making everyone curious is why a 305?
generally people beef up 305's because they lack the money to pull it and put in a 350, but if your buying a set of heads, cam, intake and a new carb why not buy a 350? that is what is confusing.
Old 08-21-2011, 02:36 PM
jmaine83's Avatar
well i got the engine was told it was a 350.....u get smarter by the day run the casting # its a 305 tryin to make the best of it, hate to remove it after few months and had to change alots of parts on car from 3.8engine to 5.0 olds to chevy
Old 08-21-2011, 03:11 PM
Blazin72's Avatar
Wiki Edits: 19
That's where you cut your losses and move on. You can build any engine you choose but keep in mind that the same parts you put in a 305 can make ~25-30 more hp just by bolting them on a 350. On top of that, a 350 will drop right in place of your 305 without any modifications.
Old 08-21-2011, 09:55 PM
do a Craig's List search in your area for a 350 vortec engine (complete engine, 1996 to 2000).
these factory roller engines make 300hp with only a set of headers, intake, and carb.
Old 08-22-2011, 02:17 PM
jmaine83's Avatar
what 350 should i look for 4 bolt main or 2 on what years are the best 70s 80s 90s and what casting# are the best?
Old 08-22-2011, 02:41 PM
don't worry about the number of main bolts.
The best year is the 96 to 2000 350 vortec engine.
engine combo help caprice75 Engine 6 02-28-2011 04:39 PM
engine combo mbbigboo Introduce Yourself 2 12-31-2010 12:58 AM
355 engine combo DBourg Engine 1 02-24-2008 05:38 PM
My engine combo 65coupe351w Engine 0 05-08-2007 08:57 PM
Please help, engine combo malibu68 Engine 4 12-02-2004 03:09 PM
