-   -   best cure for mangled lower control arm bolt holes (http://www.hotrodders.com/forum/best-cure-mangled-lower-control-arm-bolt-holes-231587.html)
h0trod 04-07-2013 11:35 AM
im workin on my buddys 57 chevy belair.
doing a full caltek suspension package.
on the drivers side lower control arm, one of the bolts on the stock control arm, almost pulled thru the frame.
i didnt notice, until i put the new tubular arm on, and theres a significant gap inbetween the frame and control arm, the bolt (new 7/16-fine, grade 8) would not pull it together. i tried tightening it but to only de-thread the bolt. same with a 7/16 corse thread bolt.
my oxy is gone so heat is out of the question for a sunday.
i could cut it out, or grinding it, but this will weaken the frame.
what would you do?????
thanks guys!
MARTINSR 04-08-2013 09:36 AM
I can't see it but obviously welding it is what SHOULD be done, repairing it properly. There are some gray areas that I don't want to even suggest.
If you posted some photos maybe it would be a lot clearer and something could be done but right now, broken frame, control arm mount broken out? Weld it properly.
h0trod 04-11-2013 10:47 PM
the bolt didnt pull through all the way, i got off my behind, filled the tanks, heated it up,bent it back, and put an extra thick washer on it and welded it up.
shes golden now :thumbup:
MARTINSR 04-12-2013 08:33 AM
Yep, sometimes you just have to bust out the big boys. :D
